Unexpected surface created when using Extrude Cut tool - With Video
engineeringNCMXB
engineeringNCMXB
This has me stumped. When trying to cut a feature into my model, a surface is created that covers geometry that it should not cut. I have tried this a number of different ways, including starting from scratch. Any ideas why this is happening? User error? Software bug?
Grateful for any guidance.
Carlos Acosta
Factory400 - YouTube|Instagram
TrippyLighting
Can you share the model?
engineeringNCMXB
Sure - let me de-feature it a bit and I will share. Standby.......
Carlos Acosta
engineeringNCMXB
In the process of making a de-featured copy.....I discovered something that helps. It feels like I am working around a bug on this one. Strange.....
I moved the sketch plane up, then extruded to the top surface and used an offset to get the cut. It works, but I have no idea why. If I cut directly to the depth, I get the unexpected surface.
Carlos Acosta
jeff_strater
one of two things is possible here:
  1. this is a graphics/faceting glitch, in which case the geometry is fine, but the display just has a few extra triangles
  2. there is a sketch visible, and what you are seeing is that sketch
my money is on #1, but we can't tell without the model.
Jeff Strater
Engineering Director
