Unexpected movement during a 2D Contour
j9lemmon
j9lemmon
I created a 2D Contour to cut out a part. When ran a Simulation there was an expected movement at one outside corner; it looked like it was drilling a hole at the point. This was at the retract location. In the toolpath, there was a stack of green arrows at the point. Screenshot attached.
davebYYPCU
That looks like lead in out settings,
If you did not consider that or ramp settings, I would not consider them unexpected.
Posting in the CAM forum will expose you to the CAM gurus, who may not monitor this area.
Might help....
j9lemmon
Thanks, @davebYYPCU
I'll post in CAM
j9lemmon
I did post again in CAM. @davebYYPCU  and got a quick reply. And you were correct that Lead-ins were the issue.
Thanks!
