I am not 100% sure but I think that when previously editing a body in Sculpt mode we could use the undo command whilst edit mode was active.
There is a second issue, create a cube and use the Modify tool to pull a face, and then use the undo command with the tool still active.
Solved by mstrater. Go to Solution.
Thanks for pointing this out. You are correct, we have a known regression in this area. Sorry about that.
For internal reference we have it logged as FUS-30110.
