Once again, I have proven I don't know what Im doing....
I've attached a small project that cuts two parts out of a single board. I need to chamfer the parts (RED), but am having issues getting what I want. The only bit I have for chamfering is an Amana 45711 90 degree. I guess I don't know the proper way to setup this tool path because the simulation does not look right. The areas in the pic makered with an X are waste
Any help would be appreciated.
You could use Trace. You'll need a Sketch entity (linE) to select. I'd do all four leaving sat 1.5mm of material first Toolpath of the whole job then repeat to full depth last operation
