- Mute
- Permalink
- Report
So to begin with, I am new to Fusion 360. I have only been using it for three days and there is something I don't understand. When working in sheet metal, I want to use the bend feature.
As I can tell, you have to create the steel sheet sketch first.
Supposedly you have to select which "side" you want to bend. Side 1 or side 2. I have seen more than one way to attempt bending but none of them make any sense.
Some people put the bend lines in during the first sketch. Some people put them in on a second sketch and then hide the first sketch... I think. Its all explained way to fast and when I do get all the steps it does not work.
I need a step by step instruction from, what I hope would be an AUTODESK employee, so I can attempt to make my part. There is NO consistency in how to do this that I have been able to find. The closest I got was a woman that posted a video in the forum but, she imported a file and a bunch of other stuff I didn't understand.
I can not share the shape of the sheet metal I am going to start with. I'm just not allowed to. There are 7 bends I need to make. I CAN NOT use the flange feature to extrude the profile. It has to be the sheet metal bending feature only.
Thank you.
