Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Unable to use Fusion360
5 REPLIES 5
rbenji23
1028 Views, 5 Replies
I have been unable to successfully start Fusion 360 for quite some time and it seems none of the updates ever resolve the issue. Any ideas what the issue could be?
Computer Info:
OS X El Capitan 10.11
MBP 15in (Late 2013)
2.3Ghz I7 16gb Memory, Iris Pro Graphics
Here are the log entries when I try to start Fusion 360 with wifi turned on and connected:
10/1/15 11:03:09.759 PM Autodesk Fusion 360[2898]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.0 instead of 10.11.0. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
10/1/15 11:03:09.760 PM Autodesk Fusion 360[2898]: 0   CarbonCore                          0x00007fff939a379f ___Gestalt_SystemVersion_block_invoke + 113
10/1/15 11:03:09.760 PM Autodesk Fusion 360[2898]: 1   libdispatch.dylib                   0x00007fff867b0453 _dispatch_client_callout + 8
10/1/15 11:03:09.760 PM Autodesk Fusion 360[2898]: 2   libdispatch.dylib                   0x00007fff867b034b dispatch_once_f + 67
10/1/15 11:03:09.760 PM Autodesk Fusion 360[2898]: 3   CarbonCore                          0x00007fff9393009c _Gestalt_SystemVersion + 987
10/1/15 11:03:09.760 PM Autodesk Fusion 360[2898]: 4   CarbonCore                          0x00007fff9392f8b0 Gestalt + 139
10/1/15 11:03:09.760 PM Autodesk Fusion 360[2898]: 5   QtCore                              0x000000010e205916 _GLOBAL__I_a + 22
10/1/15 11:03:09.760 PM Autodesk Fusion 360[2898]: 6   ???                                 0x00007fff62055f1b 0x0 + 140734837907227
10/1/15 11:03:13.940 PM Autodesk Fusion 360[2898]: dynamic_cast error 2: One or more of the following type_info's  has hidden visibility.  They should all have public visibility.   N3OGS7Objects6ICloneE, N3OGS7RapidRT19RapidRTPublishAgentE, N3OGS7Objects18IOneTimeInitializeE.
10/1/15 11:03:13.941 PM Autodesk Fusion 360[2898]: dynamic_cast error 2: One or more of the following type_info's  has hidden visibility.  They should all have public visibility.   N3OGS7Objects6ICloneE, N3OGS7RapidRT19RapidRTPublishAgentE, N3OGS7Objects11ARefCountedE.
I have tried the suggestions listed here:
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
http://forums.autodesk.com/t5/design-and-documentation/fusion-360-crashes-in-os-x/td-p/5499708
http://forums.autodesk.com/t5/api-and-scripts/os-x-el-capitan-beta-issues/td-p/5690467
Here are the log entries when I try to start Fusion 360 with wifi turned OFF at launch then turned on once past splash screen:
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.0 instead of 10.11.0. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: 0   CarbonCore                          0x00007fff939a379f ___Gestalt_SystemVersion_block_invoke + 113
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: 1   libdispatch.dylib                   0x00007fff867b0453 _dispatch_client_callout + 8
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: 2   libdispatch.dylib                   0x00007fff867b034b dispatch_once_f + 67
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: 3   CarbonCore                          0x00007fff9393009c _Gestalt_SystemVersion + 987
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: 4   CarbonCore                          0x00007fff9392f8b0 Gestalt + 139
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: 5   QtCore                              0x00000001059c2916 _GLOBAL__I_a + 22
10/1/15 11:35:39.112 PM Autodesk Fusion 360[3103]: 6   ???                                 0x00007fff61c2bf1b 0x0 + 140734833540891
10/1/15 11:35:46.550 PM spindump[485]: Saved spin report for Autodesk Fusion 360 version 2.0.1633 (2.0.1633) to /Library/Logs/DiagnosticReports/Autodesk Fusion 360_2015-10-01-233546_Reids-MacBook-Pro.spin
10/1/15 11:35:47.924 PM Autodesk Fusion 360[3103]: dynamic_cast error 2: One or more of the following type_info's  has hidden visibility.  They should all have public visibility.   N3OGS7Objects6ICloneE, N3OGS7RapidRT19RapidRTPublishAgentE, N3OGS7Objects18IOneTimeInitializeE.
10/1/15 11:35:47.924 PM Autodesk Fusion 360[3103]: dynamic_cast error 2: One or more of the following type_info's  has hidden visibility.  They should all have public visibility.   N3OGS7Objects6ICloneE, N3OGS7RapidRT19RapidRTPublishAgentE, N3OGS7Objects11ARefCountedE.
10/1/15 11:35:55.885 PM Autodesk Fusion 360[3103]: error: Error Domain=NSURLErrorDomain Code=-1009 "The Internet connection appears to be offline." UserInfo={NSUnderlyingError=0x7fa27faef950 {Error Domain=kCFErrorDomainCFNetwork Code=-1009 "The Internet connection appears to be offline." UserInfo={NSErrorFailingURLStringKey=https://pages.autodesk.com/productinfo-72ce4c5d58b6c0f791ef9de1eefcb212.html?minfo_source=fusion360product&minfo_action=usage&minfo_feature=ApplicationLaunch, NSErrorFailingURLKey=https://pages.autodesk.com/productinfo-72ce4c5d58b6c0f791ef9de1eefcb212.html?minfo_source=fusion360product&minfo_action=usage&minfo_feature=ApplicationLaunch, _kCFStreamErrorCodeKey=8, _kCFStreamErrorDomainKey=12, NSLocalizedDescription=The Internet connection appears to be offline.}}, NSErrorFailingURLStringKey=https://pages.autodesk.com/productinfo-72ce4c5d58b6c0f791ef9de1eefcb212.html?minfo_source=fusion360product&minfo_action=usage&minfo_feature=ApplicationLaunch, NSErrorFailingURLKey=https://pages.autodesk.com/productinfo-72ce4c5d58b6c0f791ef9de1eefcb212.html?minfo_source=fusion360product&minfo_action=usage&minfo_feature=ApplicationLaunch, _kCFStreamErrorDomainKey=12, _kCFStreamErrorCodeKey=8, NSLocalizedDescription=The Internet connection appears to be offline.}
10/1/15 11:36:22.005 PM Autodesk Fusion 360[3103]: javascript is:
 neutronJavaScriptHandler.handle('connectivityChanged','{"status":"connected"}')
10/1/15 11:36:30.715 PM spindump[485]: Saved spin report for Autodesk Fusion 360 version 2.0.1633 (2.0.1633) to /Library/Logs/DiagnosticReports/Autodesk Fusion 360_2015-10-01-233630_Reids-MacBook-Pro.spin
If I launch Fusion 360 with the wifi off I will get past the splash screen but then the main window is just blank. If I try to connect to wifi, it will usually hang again or just stay blank.
It gives me the same issue on both my home network and the public wifi network.
5 REPLIES 5
Stuart-H
in reply to: rbenji23
Have you by third party apps installed like little snitch
it's not a fusion problem you have some software reporting false info
have you tried a new account for the Mac IE create a new user for the Mac and log into that redownload the fusion client and see how it goes, make sure the new acct has admin rights
Stuart
Mac Studio M1Max and MacBook Pro M1
innovatenate
Could you post a couple of screenshots of the issue? It sounds like it may be a network connectivity issue. Are you connected to the same network everytime?
If you have any anti-virus software running on the Mac, can you try disabling to see if it helps? The same goes for a firewall. You can temporarily disable and then re-test.
Would you mind manually collecting the log files from the computer and posting them here? They may contain some further information to help us diagnose the issue.
To collect Installation Log File (for install or update errors):
Windows OS
C:\Users\%USERPROFILE%\Appdata\Local\Autodesk\autodesk.webdeploy.streamer.log
Mac OS
Macintosh HD/Users/<LOGIN>/LIbrary/Logs/autodesk.webdeploy.streamer.log
Application Log Files (for issues launching or operating Fusion 360):
Windows OS
C:\Users\%USERPROFILE%\Appdata\Local\Autodesk\Autodesk Fusion 360\<ID>\logs ... (look for all *.log files)
Mac OS
Macintosh HD/Users/<LOGIN>/LIbrary/Application Support/Autodesk/Autodesk Fusion 360/<Custom ID>/logs ... (look for all *.log files)
Let us know if you have any questions.
Nathan Chandler
Principal Specialist
rbenji23
in reply to: innovatenate
I have tried two different networks and have the same issue on both.
I have tried it without virus scan, and added fusion 360 to allow all connections in the firewall. I also tried with the firewall completely disabled.
I also tried running it on a newly created admin account.
Here are all the system log entries when I try to launch fusion 360:
10/3/15 11:52:00.753 AM SpotlightNetHelper[2674]: [SLSUGGESTIONS] PRSSearchSession received an error (-1001) while searching
10/3/15 11:52:00.754 AM SpotlightNetHelper[2674]: [SLSUGGESTIONS] PRSSearchSession received an error (-1001) while searching
10/3/15 11:52:10.754 AM networkd[196]: -[NETProxyLookup pacLookupComplete:proxies:error:] PAC evaluation error: Error Domain=kCFErrorDomainCFNetwork Code=-1001 "(null)"
10/3/15 11:52:18.418 AM networkd[196]: -[NETProxyLookup pacLookupComplete:proxies:error:] PAC evaluation error: Error Domain=kCFErrorDomainCFNetwork Code=-1001 "(null)"
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.0 instead of 10.11.0. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: 0   CarbonCore                          0x00007fff9914b79f ___Gestalt_SystemVersion_block_invoke + 113
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: 1   libdispatch.dylib                   0x00007fff8bf58453 _dispatch_client_callout + 8
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: 2   libdispatch.dylib                   0x00007fff8bf5834b dispatch_once_f + 67
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: 3   CarbonCore                          0x00007fff990d809c _Gestalt_SystemVersion + 987
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: 4   CarbonCore                          0x00007fff990d78b0 Gestalt + 139
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: 5   QtCore                              0x000000010af21916 _GLOBAL__I_a + 22
10/3/15 11:52:23.880 AM Autodesk Fusion 360[2935]: 6   ???                                 0x00007fff650ecf1b 0x0 + 140734888857371
10/3/15 11:52:25.078 AM launchservicesd[84]: SecTaskLoadEntitlements failed error=22
10/3/15 11:52:25.080 AM launchservicesd[84]: SecTaskLoadEntitlements failed error=22
10/3/15 11:52:31.194 AM appleeventsd[54]: SecTaskLoadEntitlements failed error=22
10/3/15 11:52:32.631 AM Autodesk Fusion 360[2935]: dynamic_cast error 2: One or more of the following type_info's  has hidden visibility.  They should all have public visibility.   N3OGS7Objects6ICloneE, N3OGS7RapidRT19RapidRTPublishAgentE, N3OGS7Objects18IOneTimeInitializeE.
10/3/15 11:52:32.631 AM Autodesk Fusion 360[2935]: dynamic_cast error 2: One or more of the following type_info's  has hidden visibility.  They should all have public visibility.   N3OGS7Objects6ICloneE, N3OGS7RapidRT19RapidRTPublishAgentE, N3OGS7Objects11ARefCountedE.
10/3/15 11:52:38.824 AM pkd[2627]: SecTaskLoadEntitlements failed error=22
The  requested other log files are attached.
Still not having any luck with anything.
Thanks for all help!
rbenji23
I think I may have gotten it figured out. I unchecked the Auto Proxy Discovery box checked in the attached pic and then it worked.
Screen Shot
innovatenate
I'm glad its working. Thanks for following up to let us know what solved the issue for you!
Nathan Chandler
Technology Administrators
