Unable to start Fusion 360
richard4sa
Message 1 of 10
richard4sa
Hi
When I open Fusion 360 I get the following message:
"You have been working in offline mode for more than the allowed period of 2 weeks. Please login to your A360 account to continue."
Fusion then start to load, but then stops and exits the program before anything can be selected.
Is there another way to log in?
Thank You
Replies (9)
Message 2 of 10
Phil.E
As the message states, you need to login to A360.
http://autodesk360.com/
Go to this link and log in. This is the dashboard of your Fusion work. It is used to manage data, manage collaboration with other users, create projects, etc.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 10
ji-young
Could you let me know how you got into the situation? It will help us to find better solution to the problem.
Did you manually turn on the offline mode and continue using it for more than 2 weeks and then end up with the message?
Thank you,
Ji-Young Oh.
UX Designer, Fusion 360
Autodesk, Inc.
Message 4 of 10
richard4sa
Hi Ji-Young
I have turned on offline mode maunually.
I and have logged in multiple times to A360 and reinstalled Fusion 360, but it still crashes just after loading.
Let me know of any additional information you might require.
Thank You
Message 5 of 10
marshaltu
Please take a look at the following thread. That issue may be similar to yours.
http://forums.autodesk.com/t5/general-fusion-360-questions/problems-launching-fusion/td-p/5294153/pa...
Marshal Tu
Fusion Developer
Message 6 of 10
ji-young
Thanks for the reply. I will follow up with our engineering to identify the cause.
In the meanwhile, please try out the solution that Marshal provided in her link.
Ji-Young.
Autodesk, Inc.
Message 7 of 10
richard4sa
Thank You
Fusion is starting after deleting the options file.
Message 8 of 10
What if you don't have an options file ?
Message 9 of 10
Message 10 of 10
innovatenate
Autodesk Support
Autodesk Support
Do you see the other directories listed in the path  (e.g. Nuetron Platform, etc..)?
Mac
~/Library/Application Support/Autodesk/Neutron Platform/ Options
Windows
C:\Users\USERNAME\AppData\Roaming\Autodesk\Neutron Platform\Options
Are the files/folders hidden?
To show hidden Files and Folders:
Mac OS:
  1. Open Terminal found in Finder > Applications > Utilities.
  2. In Terminal, paste the following: defaults write com.apple.finder AppleShowAllFiles YES.
  3. Press return.
  4. Hold the 'Option/alt' key, then right click on the Finder icon in the dock and click Relaunch.
Windows:
  1. Open Folder Options by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options.
  2. Click the View tab.
  3. Under Advanced settings, click Show hidden files, folders, and drives, and then click OK.
I hope this helps!
Nathan Chandler
Principal Specialist
