Can't load files on MAC
macmanpb
macmanpb
I can't load a files from dashboard. When i doubleclick this file in dashboard, fusion shows a loading indicator but nothing happends.
Normally Fusion shows a information in the top left corner "opening design..." but in my case this message is not showing.
I have wait a lot of time to see changes but the file was not loaded. Network and internet are working fine.
I sign out and sign in with no changes. I hope my file is not broken, it is large and complex.
Please help!!!! Smiley Sad
innovatenate
Autodesk Support
Autodesk Support
I've sent you a PM with a suggestion. Please let me know if it helps and if you have any other quetsions/concerns.
Nathan Chandler
Principal Specialist
Hi I am having the same problem. It used to work fine. Could you please help ?
josef.kucera
Hello rahul.koduri,
do you still have problem with loading files on MAC?
if yes, please could you send me a zipped whole folder "Autodesk Fusion 360" from "~/Library/Application Support/Autodesk/" in case if you had downloaded and installed Fusion360 from Autodesk web pages
in case of AppStore look for the folder here: "~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Autodesk Fusion 360"
to my Autodesk email: josef dot kucera at autodesk dot com
Thank you for your help.
Josef
Josef Kucera
Fusion QA
I am getting the exact same problem on my Mac, it has been quite difficult to open files or almost impossible. How can I solve it?
josef.kucera
Hi marcoleite,
are you still having issue with open on your MAC after the most recent update of Fusion?
If yes, could you please send me your diagnostic log file to my Autodesk email josef dot kucera at autodesk dot com?
Josef Kucera
Fusion QA
bmxjeff
So... this thread is old, but I have the Pre-release and the standard version of Fusion and both are not showing files in my dashboard. I keep having to restart.... So, it works for a minute. I do have an eGPU that don't support the Chrome Dashboard.
launchctl setenv NEUTRON_CHROME_DISABLE_GPU 1
If I run that on start up, I can see the Pull down to switch teams.
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
