unable to make transition from a plane to a curved shape
jducifuentes
Message 1 of 10
jducifuentes
Hi, I'm newbie to fusion360. I'm trying to design a sloped corner for skatepark / RC car track. The point is to make a smooth transition between our common plane (ground) to curved shape of the corner. I attach a picture hoping clarify scenario.
Already tried loft but can't make it to follow the path I liked, only a linear pathsloped corner.png
Replies (9)
Message 2 of 10
TrippyLighting
Unless you allow for some rounding of the corner highlighted in red, making that "really" smooth is geometrically not possible. The best you can do is to apply a few patches in the Patch workspace and sew them together into a solid and combine them with the rest.
Message 3 of 10
chrisplyler
What @TrippyLighting is talking about with the lack of smoothness...
Message 4 of 10
chrisplyler
But you CAN make the single Patch flatten out if you just add a single line to use as an interior guide during the Patch operation.
Message 5 of 10
jducifuentes
Hi, thanks for your quick reply!. I'm so sorry but as I mentioned before I'm very very newbie and don't know how to use patch.... May I have to create a sketch and a line for rounding this corner?
I tried to patch the surface but nothing happens....
Message 6 of 10
TrippyLighting
You'll have to disable "Chain selection" in the dialogue. Then you can pick individual sketch elements and edges.
Message 7 of 10
chrisplyler
Watch this very slowly.
Message 8 of 10
jducifuentes
Wow! Thank you very very much, you did the trick mate! Very good explained.
Thanks for your time and effort. Today I've leart a bunch of new things...
Message 9 of 10
TrippyLighting
That lack of smoothness is not what I was taking about. What I meant is that there is not way to connect these 2 surfaces in a tangential, or curvature continuous way. There will always be a sharp edge.
Message 10 of 10
chrisplyler
Oh yes, of course.
