I'm designing an L-shaped support bracket out of steel tubing with a 45 degree bracing tube a certain distance (controlled by a user parameter) from the radiused bend. I sketched the centreline of the bracing tube and then sketched the profile of the brace on a construction plane halfway along that centreline. After extruding the profile to join the existing legs of the bracket everything was fine. But when I changed the user parameter that controlled the position of the brace, the profile (and the extrusion, of course) didn't move.
Why not?
