Unable to edit face of an object created in model mode
Hello , I am trying to create a form from model mode , I open create form , then create box , A window opens with options to edit box - how many splines , symmetry , length ,width etc . But if I close that window say to move box etc , I can no longer find that window again to make changes , If i open edit form under modify a entirely different window opens with none of the original options in first window .
Is there a way to reopen the original edit window ?
jeff_strater
Yes, your observation is correct:  In the Sculpt workspace, "primitives", such as Box, Cylinder, etc are not editable, as they are in Model workspace.  So, you cannot get back to the Box creation dialog in Sculpt.  You would have to either delete the box and start over, or use commands such as Edit Form to modify the box, once it has been created.
Jeff
Jeff Strater
Engineering Director
Thanks , Quickly learning
