Unable to create joint without errors (new user)
- Mute
- Permalink
- Report
Hi, fairly new user here and this is my first post. Hope someone can give me a hand with my questions or point me in the right direction.
Introduction
I've been trying to teach myself how to use Fusion by watching YouTube video's and by a lot of experimentation and trial and error. This with the end goal of using CAD to design (and then build) a lot of items in my home renovation project. Specifically items such as inbuilt wardrobes, utility cabinets, bathroom cabinets and my workshop workbenches.
Context
I've started by recreating the workbench in Fusion that I recently built in real life from a set of purchased Sketchup plans. It took me quite a long while but I eventually succeeded in getting a perfect copy of the Sketchup model and my real life workbench. However, I didn't use the correct workflow and only managed to get there with a lot of yellow items on my timeline. I mainly succeeded in getting the desired end result by trying and retrying until things looked right. And not by always fully understanding why something did or didn't work out. This first project did get me very motivated to better learn how to create with Fusion though.
First real project (with a lot of warnings)
So I decided to start again from scratch, apply my lessons learned, to use Parameters from the get-go and to learn why things do or don't work in Fusion. Specifically so that I can create variations of the initial workbench design by setting different widths and depths in the Parameters, as I'll be building a very wide workbench soon to cover an entire wall in my workshop.
Current issue
I thought I was doing well, with no yellow or red in my timeline, having all sketches dimensioned/ constrained and by using parameters, joints and rigid groups. Until I copied a component and tried to join it like I had done with the original component.
I can't seem to get this copied component joined where I want it to go without a warning. I can get it in the correct position by just moving it but I think then the model would break when I change the dimensions in the parameters.
Example of what I see when I try to join
Question(s)
- What am I doing wrong here? / how can I create the join I'm looking for (see image from the purchased Sketchup plans below the second question)
- Is there a resource where I can learn what the icons mean that I see when I hover over a "jointable point" in the design? I now just keep trying all variations until the animation shows me the move I'm looking for.
Joint that I'm trying, but failing, to recreate: the upper centerrail
- The first file I made that looks good but was made with a lot of warnings (Hooked on Wood Workbench without parameters v2.f3d)
- The current file where I try to recreate the first file but now by doing everything correctly (Paramatric design Hooked on Wood workbench nr2 v18.f3d)
