How to move a constrained rectangle?
ronydee
Message 1 of 9
ronydee
Reference to the attached project file: PCB Enclosure: Sketch15
I modified the shell thickness which affected Sketch15 position.  Now I need to move Sketch15 up, where the bottom of the rectangle to  be flush with the new shell thickness?
Replies (8)
Message 2 of 9
Drewpan
I am very unsure as to what you want to do. Can I have some more information please?
So far I have solved the yellow flag in the timeline by associating Sketch 15 with the same level as the cutout.
Is this what you want?
BTW. Two of your sketches are not fully constrained that may cause you issues. Also, what happened to the other
 sketches? Deleting or Removing information from a design is a BAD idea as it breaks the workflow chain and
makes it harder to work out what went on earlier in the design.
Moving and capturing position is a BAD workflow. If you are not going to Design in Place and use as As-Built Joint
then turn off the visibility of the Components in the way, Design from the Origin and then use a normal Joint.
Cheers
Andrew
Message 3 of 9
ronydee
Hi Drewpan,
thank you for replying.  Man you guys are certainly top notch understanding 3D modeling.  I'm just learning as I go before running into a wall.  Just a hobbyist modeling simple designs for the  drum conversions to electronics. I wish there was a course I could take other than watching youtube videos and constantly searching on the forum, but sometimes they do not talk about certain aspects as you mention.
Anyway, the attached pic hopefully explains what I need to accomplish.  The other sketch (PCB sled): I  ungrounded to the PCB enclosure so I could separate both.  The PCB sled slides into the enclosure.  Sketch15 is what the sled will slide into.
I need to go back and look at constraints again so I know what to look for anything that is not constrained.
thank you again
Ron
Message 4 of 9
Drewpan
The best way to get your teeth into fusion is check out RULE #0, 1 & 2 pinned to the top of the forum. They revolve
around reading the Docs, doing the embedded tutorials and getting stuck into the Self Paced Learning. Time spent
doing this is NEVER wasted. Then check out the AutoDesk Fusion YouTube Channel. All sorts of good stuff at all
levels. AutoDesk University is also good.
In terms of fixing your floor in the enclosure, you can do it a couple of ways. If the sketch is exactly the correct
shape just not in the plane you want it then you can do an extrusion but instead of from the profile plane, extrude
from an Offset or an Object.
The other way you might be able to do this is with the Press Pull command, where you literally select the face and
pull or push it up or down.
Try those and see what you get.
Cheers
Andrew
Message 5 of 9
davebYYPCU
Edit the file, hide (eyeballs) the body, and first 2 sketches,
Edit Sketch 15, window select and delete all of this sketch.  Unhide the body
Create > Project > Intersect - set to body, click on the inside wall of the box where sketch 15 is, say Ok, Hide the body.
(Should have the wall and cabinet pieces in purple)
Draw a line and dimension it above the floor.  (old one was 3mm high) Connected to the front and back vertical lines.
Finish Sketch.
Edit the yellow Extrude feature, right click and select edit feature.
Reselect the 3mm rectangle for the extrude.  Say Ok.
Will look like these.  (It is very common to go back in the timeline and edit stuff with new ideas)
Might help....
Message 6 of 9
g-andresen
I would like to point out that this question has already been asked in the same way in
this thread
günther
Message 7 of 9
ronydee
Yeah i was thinking since this was a different task i placed it in a new thread.  Maybe not.. sorry for confusion thank you.
Message 8 of 9
ronydee
Wow excellent.. another operation learned “intersect”. I will review  Thank you 🙏
Message 9 of 9
ronydee
Thank you for valuable info.  I will defintely spend time .. important for sure 👍
