11:52 AM
- Mute
- Permalink
- Report
I am following a tutorial, and everything seems fine until they say to create something, say a rectangle on the top. no matter what I try, the rectangle always appears on the bottom surface, and refuses to move in the z direction. Im wondering if I turned off/on something by mistake? Previously I made a flat shape, then extruded it up to make a solid if this helps? It is selecting fine as a body, but the rectangle won't select as a whole even on the bottom, I can only select the individual lines. I have tried turning the other layers off, but it still won't have it.
Link copied
