Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
unable to create anything on the top surfacer
15 REPLIES 15
Message 1 of 16
778 Views, 15 Replies
I am following a tutorial, and everything seems fine until they say to create something, say a rectangle on the top. no matter what I try, the rectangle always appears on the bottom surface, and refuses to move in the z direction. Im wondering if I turned off/on something by mistake? Previously I made a flat shape, then extruded it up to make a solid if this helps? It is selecting fine as a body, but the rectangle won't select as a whole even on the bottom, I can only select the individual lines. I have tried turning the other layers off, but it still won't have it.
15 REPLIES 15
Message 2 of 16
jhackney1972
If I am reading your issue correctly, you are creating the second sketch, your rectangle, on the same origin plane as your first sketch.  Select the surface of the solid body, then right click and select Create Sketch to place your sketch on the top surface.
John Hackney, Retired
Message 3 of 16
laughingcreek
it would be helpful to include more visual information with your question.  pics, a screen cast, your model.  something to give more indication of where you might be going wrong.
a link to the tutorial (and the time stamp) might also be helpful.
Message 4 of 16
in reply to: jhackney1972
I have tried that, but it deselects when I select the tool, or won't let me select anything but the whole body?
Message 5 of 16
in reply to: laughingcreek
Screenshot 2020-06-09 at 20.20.53.pngsorry, took ages to remember how to do this on a Mac!
Message 6 of 16
its a Udemy tutorial, so wasn't sure you'd have access? its the make a wrench chapter of designing for 3d printing with fusion 360
Message 7 of 16
jhackney1972
I have included a Screecast of what I think your process is.  As @laughingcreek mentioned, you need to give more information in your forum questions so others can help both quicker and more direct to your exact problem.  If you are in a tutorial, the hyperlink and timestamp in the tutorial is needed, if you have a model with a problem attach it.  Also screen captures will help explain your issues and best of all a Screencast.  You will find quick help for the forum users if you post your questions in this form.
Message 8 of 16
OK, I went back to the sketching mode of the first sketch, then finished sketch, the extruded, then when I hover the mouse, the whole body selects, not the faces? How have a managed to group it all? 😂Screenshot 2020-06-09 at 20.41.20.png
Message 9 of 16
OK, To keep it simple, I tried to copy you and just did a rectangle, extruded it, and then it still won't let me select a surface?Screenshot 2020-06-09 at 20.54.10.pngScreenshot 2020-06-09 at 20.54.43.pngScreenshot 2020-06-09 at 20.54.31.png
Message 10 of 16
sorry, those were in the right order! but hopefully you can see all the settings I am using ok
Message 11 of 16
laughingcreek
check your selection settings, just to make sure you didn't disable face selection.
Message 12 of 16
TheCADWhisperer
Post screen shot of your active Selection Filters.
Well, I guess I'm too slow today.
Message 13 of 16
Fab, that was it, **** my shaky hands, only body selection was active, all else off! Thanks 🙂
Message 14 of 16
jhackney1972
Check your Select choices on the end of the toolbar.  You must have Body Surfaces checked.  Just use the Select All check is the easiest method.  You also can use the Selection Priority command to chose Face Priority but then you have to turn it off later to select other entities.
Message 15 of 16
Great, thanks! I thought it was probably something small like that 🥰
Message 16 of 16
in reply to: TheCADWhisperer
Great! Yes, that was it, thanks 😊🙄
