Unable to add appearance to certain portions of a component
I am new to using Fusion 360, and I am seeming to have some issues applying appearance (just paint).  In another components, I can select the specific cut and then apply a certain color to it.  For some reason, in this component, when I have the portion selected I would like to adjust the appearance of, and then click "appearance" from the right-click, it instead highlights the whole component, as seen in the provided screenshots.  The same thing happens when I select the "5" or "0" engraving to change the appearance.  I am wondering if I did something wrong in the design portion of the this component? I am trying to learn good practice as I learn the software to avoid issues like this in the future.
Thanks!
sandris.vitolins
If I understand correct, then You need to select face instead of body and then select each face. I think so...
Unfortunately, that still is not solving it! I had already tried that and just tried again.  Thanks for the response.
