Type of joint in Fusion 360
Hi,I am Vipin.V.G
Is there any type of joint in Fusion 360 that is logically same as 'Path mate' in solidworks.
All I need is the red colored pin( please refer image) should slide along the semi circular path
TrippyLighting
If the path just a part/segmeent of a complete circle, then you can use a revolute joint around the center of that circle segment. It is its not really circular, e.b\g. al ellipse, or it is not a continuous curvature such as includes linear segments or varying curvature (spine, ellipse etc.) then there is currently no joint type for this.
Others might suggest using a contact set. I advise against it!
bharamk
Please find the attached Screencast.
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
