Two-turn Möbius strip
kandennti
Mentor Mentor
Message 1 of 8
kandennti
Hey everyone.
A Möbius strip is made by twisting the rectangular sides 180° and attaching the ends to each other.
If you turn it around twice and attach the ends, it will look like this.
As it is, there is a self-intersection.
If you drill a hole to remove the interference, it will look like this.
I have created an add-in to create this shape.
https://github.com/kantoku-code/Fusion360_Two-turn_Mobius_strip
It may not be useful for your design.
However, you may enjoy it for a little while.
I carved this out of chemical wood.
Replies (7)
Message 2 of 8
TrippyLighting
Very nice work!
Message 3 of 8
JeromeBriot
Bravo !
Can you give us more information about this process?
Message 4 of 8
JeromeBriot
I think you should add the ConstructionPoints filter to the SelectedCommandInput object so we can directly select the origin without creating a sketch first.
In MobiusStripCore.py:
_point = SelectionCommandInputHelper(
    'pointIpt',
    lm.sLng('Center Point'),
    lm.sLng('Select Sketch Point'),
    ['SketchPoints', 'ConstructionPoints'])
Message 5 of 8
kandennti
Thank you @TrippyLighting .
It won't help you, but I think you will enjoy it.
I forgot to attach the video.
Message 6 of 8
kandennti
Thank you@JeromeBriot .
Since my company only has a 3-axis machining center, I divided it into 5 pieces, machined them, and glued them together.
https://kantoku.hatenablog.com/entry/2021/03/17/084849
I'm thinking of a way to machine it without splitting it, but I can't come up with a good idea.
Message 7 of 8
kandennti
@JeromeBriot .
The reason why I used only points in the sketch is because I needed the direction of the plane. That's why I couldn't use ConstructionPoints as a filter.
Message 8 of 8
TrippyLighting
I completely skipped over the fact that you created a plugin. Incredible!
As you also made the "thing" this really captures the essence of Fusion 360!
