Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Twisting/Spiral an extrusion
2 REPLIES 2
j_haustein
84 Views, 2 Replies
I know I have seen something similar before, but I can't find how to do it.
In this example i have a polygon shape that is around my base object sort of, now to make it more interesting I want the polygon not straight up I want it spiral up or twist up if that makes sense is there an easy/fast way to do this?
Tags (3)
Labels (3)
2 REPLIES 2
evanp4509U4JZ
in reply to: j_haustein
Do you mean like this? Sketch a path and use sweep. The menu offers options on angle and taper
j_haustein
AH yes exactly like that thank you so much for your help!
