I know I have seen something similar before, but I can't find how to do it.
In this example i have a polygon shape that is around my base object sort of, now to make it more interesting I want the polygon not straight up I want it spiral up or twist up if that makes sense is there an easy/fast way to do this?
Solved by evanp4509U4JZ. Go to Solution.
Do you mean like this? Sketch a path and use sweep. The menu offers options on angle and taper
