Twisted leaf design help.
Hello.
I'm new in the fusion 360 world 🙂 I read lots of forums and whatched lots of tuto on youtube, but i can't find any particular solution to my problem...
I'm trying to reproduce a "twisted leaf curtain rod tip" that I broke.
The dimensions of the leaf (without the circular support ) are 100mm width, 125mm high and 45mm depth.
I have tried differents approach and tools (different offset plans and loft, rotation, sculpt mode etc), but can get any acceptable result...
What are you advise ?
Thanks a lot for your help !
Emmanuel
(sorry for my english 🙂 )
TrippyLighting
The key to this shape is probably a the sculpt workspace with "soft modification" enabled.
Thank you for this information Peter !
Will Try it !
It would be great to draw one side of the leaf like this then make a mirro to have a fully symetrical result.
Emmanuel
Thanks a lot for your help !!!
