[Tutorial] - How to create a Worm Gear
Beyondforce
Advisor Advisor
Beyondforce
Hi Everyone,
I hope you'll enjoy this tutorial. Please let me know if you have any question.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
This design will not work very well. If you turn the treat 180 deg and make another cut you will see that there will be a lot of collition. I'm trying to find a way to cut turning while moving both parts. You could turn the treat 1deg a time and cut as you go but that is alot a cuts for 1 tooth to pattern...
radzimir
As kubbenga.pvcvloeren stated, it is good enough for presentation, but not for 3D print. Worm wheel is lacking evolvent profile.
That's why I'v created 'simply' script cutting/generating a worm gear good enough for printing.
Alas, the script does run properly. It freezes Fusion360.
... sorry for misspelling. The script does NOT run properly.
