Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Turning off the grid?
3 REPLIES 3
JetForMe
3213 Views, 3 Replies
I'm having a hard time turning the grid off. I see John Saunders's videos and in 3D or sketch modes, his grid is off. I can turn it off in 3D, but if I'm sketching, it's always on, the control is disabled, and unchecked.
macOS 10.11.6, Fusion360 2.0.2455
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
Tags (3)
3 REPLIES 3
HughesTooling
in reply to: JetForMe
Take a look at the sketch palette second option down.
Mark
Mark Hughes
Owner, Hughes Tooling
JetForMe
in reply to: HughesTooling
Thank you, and GRR WTF WHY IS IT IN A DIFFERENT PLACE??
HughesTooling
The one at the bottom of the screen is the layout\assembly grid and the other is the sketch grid. I think in the past there was only one setting, personally I like the way it is now because I don't use the layout grid but use the sketch grid most of the time.
Mark
Mark Hughes
