Message 1 of 13
- Mute
- Permalink
- Report
When you activate a component all the other components turn transparent to highlight the active component. This is useful if you then want to view/sketch on/modify etc the active component.
However, if I create a new empty component with the intention of creating a sketch for this new active component from an existing inactive component it is (depending on the complexity of the model) hard to see which inactive component you want to start the sketch on. Hope that makes sense?
So my question is simply can I turn off the automatic turning of inactive components transparent?
Thanks in advance.
Steve
