Message 1 of 16
Hello, I am new to fusion and I am working on tube coping. I have watched several videos that show splitting the one tube body with the other tube body. then they select the inside of the split body and press/pull the wall thickness and it subtracts the split section. Sounds simple however, I get an error when trying to subtract the tube wall thickness. I can subtract .001 less than the wall and I don't get an error but it also doesn't subtract the section either.
can the current version for fusion subtract body?
I cant select select the inside of the tube to split the tube body. It selects the entire tube, not inside or outside.
Thanks for any help
