Tube coping not working correctly
crectorC6Z3M
Message 1 of 16
crectorC6Z3M
Hello, I am new to fusion and I am working on tube coping. I have watched several videos that show splitting the one tube body with the other tube body. then they select the inside of the split body and press/pull the wall thickness and it subtracts the split section. Sounds simple however, I get an error when trying to subtract the tube wall thickness.  I can subtract .001 less than the wall and I don't get an error but it also doesn't subtract the section either.
can the current version for fusion subtract body?
I cant select select the inside of the tube to split the tube body. It selects the entire tube, not inside or outside.
Thanks for any help
Replies (15)
Message 2 of 16
TheCADWhisperer
@crectorC6Z3M
And provide the link to the tutorial.
Message 3 of 16
crectorC6Z3M
I have the free hobby version of Fusion, I can't seem to find the files on my drive. sorry if I am being stupid.
Message 4 of 16
TheCADWhisperer
@crectorC6Z3M
It doesn't matter what version you have...
you go to File>Export
Then you click on the ... to select the Exact Location on your hard drive that you want to place the file so that you know Exactly where it is...
Message 5 of 16
crectorC6Z3M
Got it, thank you!
Message 6 of 16
TheCADWhisperer
@crectorC6Z3M
Simply Remove the Split Body.
Click on the image above to enlarge the view.
Alternatively, you could have done and Extrude-Cut with the sketch circle.
Reading your problem description again - not sure what you really really want, but rest assured it will be easy.
Message 7 of 16
crectorC6Z3M
I am trying to make a cut on a plasma table that looks like what this guy did in this video. He split bodies using the inside surface and used push/pull to subtract the inside cut to the outer surface. pretty cool but I can't select the inside surface to make the split and further I can't subtract anything using the push/pull. Anytime I subtract the full thickness of the tube I get an error.
Message 8 of 16
TheCADWhisperer
@crectorC6Z3M
Can you post the link here so that I don't have to type it in from your image?
Message 9 of 16
TheCADWhisperer
See Attached.
Do you need a Flat Pattern for your plasma table?
Message 10 of 16
crectorC6Z3M
Sorry, I should have included it.
https://www.youtube.com/watch?v=R5V0_A9lRAU
Message 11 of 16
crectorC6Z3M
Yes, that is what I need. My plasma cuts periductular to the surface of the tube.
I didn't quite follow the surface offset and thicken but I am trying. I am new to this fusion thing but, I am learning. I have a bigger project I am working on but, I think if I can learn the basics my other questions may be solved.
Thank you for the help
Message 12 of 16
g-andresen
sorry, wrong post
günther
Message 13 of 16
g-andresen
might help
(view in My Videos)
günther
Message 14 of 16
crectorC6Z3M
I spent some time studying the file you sent. I was able to create an offset face from the inside profile and thicken it into a new body. I then split the pipe, convert to sheet metal and create a flat pattern. This is exactly what I was looking to do! Thank you very much!
I still don't know why I can't use push/pull to remove a section. If my wall thickness is .05 I can push/pull .049 but if I try .050 I get an error. I am confused, as I see a lot of videos showing push/pull to subtract a section by push/pull the full thickness.
Message 15 of 16
Warmingup1953
Do you have a tube attachment for your table?
Message 16 of 16
crectorC6Z3M
Yes I do and it does pretty well. It's a little slow to load material in it but it makes complex cuts a breeze.
