Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
TTF font not showing up
6 REPLIES 6
TurtleRacing
1245 Views, 6 Replies
I have desert dog font installed on my system, it's been there for years but it will not show in Fusion. Can you please help me get this figured out? It is already a .ttf
I have searched other font posts but nothing is working, yes I have restarted everything several times.
Tags (1)
6 REPLIES 6
in reply to: TurtleRacing
Firstly try activating the text command from menu
Once you activated the text commands window, you will see three options on the bottom right corner of your screen : txt, py and js. Please select the "txt" option if it's not ticked, then run the command "Sketch.TextWritingSystem /any" again.
TurtleRacing
That worked, Thank you!
TurtleRacing
Wait, so I have to do this every time I shut down Fusion?
Your most welcome.
Yes, you have to do it every time.
And it hardly takes few seconds to do the process, so that it is not a major concern to be worried about.
ilan.perez
What if this doesn't resolve the problem? The font still doesn't show
