Fully defining 3D sketches
First, this is not a problem in the CAD software I normally use. I have had a Fusion 360 commercial account for years, mainly for HSMWorks access, but I don't really use Fusion much anymore.
I want to create a skeleton part for an assembly (because weldments aren't a thing) that contains exactly one 3D sketch and nothing else.
The problem is with 3D sketching in Fusion; sketch entities magically lose their fully defined status for mysterious reasons. Because I can't see 100% of the sketch relations (coincident relations are hidden for some reason by default; what else is hidden?) it's hard to figure out what happened.
In this screenshot, a simple center rectangle is fully defined, and the sketch glyph has a red lock on it. I selected the XZ "top" plane when I started the sketch.
Here, I have added a leg to the tabletop, and the whole thing goes brown.
I selected the YZ "right" plane prior to doing this, but the results are identical in the XY plane.
You can replicate this yourself by starting a 3D sketch on the plane of your choice, sketching a center rectangle in the size of your choice (700mm x 500mm for me), and dropping the center onto the origin. It will go black.
Then, try to sketch a line from a corner to anywhere else, and presto the entire sketch becomes undefined.
It has always been an issue for me that I cannot measure to, or constrain to, a plane in Fusion 360, which would solve this weird issue. Am I missing something?
How would you 3D sketch a rectangle with four legs to make a table in Fusion 360?
For the record, I can make the sketch fully defined if I start this at the origin, but I don't want to put the origin there!
