Trying to split a mold - no intersection between target(s) and split tool
Hi Fusion Experts,
I've been battling a troublesome splitting issue in my attempt to make a split mold for a part. I've included a screencast below describing the issue, and I have attached the part. I apologize for my inconsistent naming of features and bodies.
I also tried using boundary fill to get the two halves, but that also failed. Also if anyone has a better method for making split molds like this I would be very happy to hear how.
Thank you very much!
- Maximilian
etfrench
I projected the splitting surface to a sketch on the side of the mold block. Extrude|Cut the rail from the mold block, then used the sketch to split the mold block.
p.s. You'll need to use a different sketch to split the upper left portion.
ETFrench
etfrench
On further review, this will only work if you can define planes for each area to split.
ETFrench
etfrench
This may work:
ETFrench
