Milling PCB in Fusion 360 from EasyEDA SVG export
I'm a hobbyist and I really like the simplicity of EasyEDA vs. Eagle for PCB design and I'm using the following workflow to get the design ready for importing into Fusion 360 for milling.
1. Export as SVG from EasyEDA (I can't get the Gerber generator to give me a file).
2. Import into InkScape, convert strokes into paths, do unions on trace paths and pads, and save as SVG.
When I insert the final SVG into Fusion 360 as a sketch and extrude it, the portions of the design that need to be removed are extruded. I could work with that except that the pad holes are not extruded.
Are there any other preparation steps I could do to get a better sketch result? Has anyone else used a workflow to go from EasyEDA to Fusion 360?
