Trying to make a smooth transition from the largest ring to the shaft
FacebookGroupMember
FacebookGroupMember
Hello all-
I am trying to make a smooth transition from the largest ring to the shaft instead of the stepping. I tried draft and loft but I can’t seem to get either to work.
Thank you in advance
FacebookGroupMember
Sketch the cross section and use a 'Revolve' instead
FacebookGroupMember
You can start with solid Loft then do the "Hollow".
g-andresen
 try this.
günther
FacebookGroupMember
I agree with Zach Carrizales , is there a particular reason you are not using revolve?
FacebookGroupMember
Yes cross section and revolve it.
FacebookGroupMember
Have you tried to choose the edge and just press delete
