Hi all, I am after some pointers on how best to achieve the results I need
FacebookGroupMember
Message 1 of 30
FacebookGroupMember
Hi all, I am after some pointers on how best to achieve the results I need. I am trying to create an STL file for the attached item but cannot seem to get going with either the easiest method to use or the best procedure. Can anyone give me some pointers please?
I am trying to create a 3d model and ultimately an STL file to allow the item to be 3d printed if possible. The problem I have is where to start! I can extrude up from the base to create a solid tube but I don't know how to create or carve the flutes into the sides. I have attached a few photos and dimensions below and would appreciate any input.
Rgds
Kev
Main Body dimensions are 144.26mm Dia, 98.25mm high, 8.15mm thick but gets thinner in the flutes at 4.94mm.
The flutes are 22.15mm wide and 73.54mm long
Replies (29)
Message 2 of 30
FacebookGroupMember
You build 1/8 of it then create circular pattern
Message 3 of 30
FacebookGroupMember
Hi Usman, but how would I go / change from the thicker base to where the flutes start ?
Message 4 of 30
FacebookGroupMember
Hi Kevan, here is an STL of the product you described. You can add chamfers and fillets as you need.
https://tinyurl.com/KevanDalby
Message 5 of 30
FacebookGroupMember
Here's how I modelled it.
Message 6 of 30
FacebookGroupMember
WoW Matt!!!! How did you do that?
Message 7 of 30
FacebookGroupMember
How can I edit that model, would it be doable with fusion 360?
Message 8 of 30
FacebookGroupMember
Admittedly I'm not a native Fusion360 user but if you drop that in to Fusion360 you can probably have a mess around with it. Someone else may be able to answer your question.
Message 9 of 30
FacebookGroupMember
thanks Matt, what would you use to edit the part? Mesh Mixer or similar?
Message 10 of 30
FacebookGroupMember
Haven't a clue 😅 I've only ever opened Fusion360 to mess around with rendering
Message 11 of 30
FacebookGroupMember
so how did you create this STL Matt?
Message 12 of 30
FacebookGroupMember
I used Autodesk Inventor and exported it to STL
Message 13 of 30
FacebookGroupMember
thanks Matt 👍
Message 14 of 30
FacebookGroupMember
You can draw the flutes on the same circular sketch you'd use for the whole cylinder, then extrude everything and use the extrude command once again to carve the flutes by switching to "cut" mode (although the program should automatically detect you're trying to remove material)
Message 15 of 30
FacebookGroupMember
thank you Emanuel, I am slowly getting there but it does not help when using YouTube guides and they are on different releases etc!!!!🥴
Message 16 of 30
FacebookGroupMember
Kevan Dalby No worries! Its night time for me here so I can't do much now, a video would make everything more clear as any modeling practice is....easier done and shown than said 😛 . I can provide you a better explanation tomorrow if you're interested and if no one comes up with a screencast on the forums in the meantime
Message 17 of 30
FacebookGroupMember
Kevan Dalby You create an arc 360/8 = 45 degree, inner and outer. Connect them. Extrude down, now you have 1/8 of the shell. Go Sketch, draw another arc to "carve" that out. Extrude 3/4 down. You chamfer the edge or using filet to smooth it out. The last step is doing circular pattern
Message 18 of 30
FacebookGroupMember
Here it is. Analize it or just convert it to STL. https://1drv.ms/u/s!Ap70qy5eHcnEge1Zdtobm5--7P3TyQ?e=9N73WF
Please let me know if I got something wrong.
Message 19 of 30
FacebookGroupMember
Nuno Gomes I personally think thats an overwhelming amount of entities/features
Message 20 of 30
FacebookGroupMember
you really dont need any more features than this
