Trying to get joints to work in an assembly
aruiz40DNGK7
Message 1 of 11
aruiz40DNGK7
Hello, for days I've been trying to get some joints to work in a piston for an assembly of a Stirling Engine. I will attach a video of how I want them to work with the fly wheel part. Also, I will attach the file in case you need to see it. I hope you guys can help me with this because I've been trying for a quite a while and I can't get it to work.
This is the video, I'm creating a Alpha Stirling Engine: https://www.youtube.com/watch?v=gQb2sN6UWkA
Accepted solutions (4)
Replies (10)
Message 2 of 11
davebYYPCU
Will get to the file later in the day, can’t see it on this device,
Ground the case, (and barrels)
revolve the crank shaft.
Revolve both rods to crank pin (both rod ends have to include offsets off vertical centre)
Revolve both rods to gudgeon pins
Slider pistons in the barrel,
Animate model, with first Revolve
Might get you going, as you did not say where you got to,
Message 3 of 11
kgilham
@aruiz40DNGK7,
It looks like you just needed the slider joints and the rotation joint.  I attached my version below.  Let me know if that makes sense or if you have any questions about it.  I'm not driving any dimensions but you can grab the piston and move them to see it working.
Kyle Gilham
Customer Advocacy Manager
Message 4 of 11
aruiz40DNGK7
It is working perfectly, thank you. But I have a quick question. Is there any way to make the fly wheel to rotate while moving the piston like the video is showing?.
Message 5 of 11
davebYYPCU
Rigid the Flywheel to the shaft.
Might help....
Message 6 of 11
kgilham
@aruiz40DNGK7  I would agree with @davebYYPCU a rigid joint would work.  If you don't want to have to measure the offset between the shaft and the flywheel you can use an As-Build joint between the two.
Kyle Gilham
Message 7 of 11
jhackney1972
Here is the assembly with the added crankshaft component.  I broke all the linked files to make it easier to upload.  DO NOT USE THIS AS YOU FINAL MODEL but you can open it easily without uploading it.  Where is you bottom cylinder housing?
Edit: @kgilham I hope you do not mind me borrowing your assembly to add the shaft into.
John Hackney, Retired
Message 8 of 11
kgilham
@jhackney1972 ,
Mine is just a copy of the original and as a major. contributor here you are always more than welcome to use any of my examples 😊
Kyle Gilham
Message 9 of 11
aruiz40DNGK7
Thank you all for your responses I've been gathering all your feedback to keep moving forward. I think I am almost done, but I have a little issue again haha. I added a crankshaft in order to connect the fly wheel to the assembly, but I cannot achieve it to revolute while moving the pistons. I will attach the file again to see if you guys can see anything that I might be doing wrong because the only thing missing to complete the project is to get the fly wheel to revolute while moving the pistons. @kgilham @jhackney1972
I will attach the video in case you are wondering what I want to achieve, and the file updated with all the work I have done.
Message 10 of 11
davebYYPCU
From what you have got now, make an Assembly > Rigid Group
select the Flywheel, Crankshaft and either Arm. If you get a warning continue.
Animate Rev 15.
I am not sure you have a "correct" model, the horizontal barrel, is not aligned to the shaft centre line, and the cranking arms are upside down, the large boss is usually on the crankshaft and the small boss holds the crankpin,
(Never surprised by newby models)
Might help....
Message 11 of 11
aruiz40DNGK7
Thank you, it worked. Yes, I know that this projects is not completely "correct", but I'm very new at this. Thank you again for all your feedback.
