Circular Extrusion Cut Help
jonhutty
Message 1 of 16
jonhutty
Hi i'm stuck on my project im trying to complete but stuck on been able to cut out a piece from my extrusion at these dimensions 21mm from the corner too cut a hole from 24mm and a height from top too bottom off 11.0mm. I hope this makes sense so what i did was is too put i line on a picture in photoshop just to show what i meant but not exact to the above dimensions. Pics below hope someone can help so i can get this project finished thanks.Magazine Sketch.jpg
Replies (15)
Message 2 of 16
jeff_strater
There is no "circular extrusion".  There is, however, Revolve.  That's how I would approach this, assuming that I understand your goal.  Apologize for having to go back and edit the sketch - I did not practice before recording.
Jeff Strater
Engineering Director
Message 3 of 16
jonhutty
Hi Jeff that is what I'm after 20.48 mm from the corners edge and 24.18 mm the hole size. I wish I could follow the video better but missed some steps and didn't get the desired result. So if you could slow the vid down slightly would be ideal. So I can follow along with this. I have to reiteriate I have only been learning fusion over the past 3 weeks now, but I am starting to get there but if you could slow it down on the video so I can tag along would be ideal and also can you still add the dimensions whats needed thanks.
Message 4 of 16
jeff_strater
one suggestion:  You can slow down the screencast here:
A follow-on question.   I think I understand "20.48 mm from the corners edge".  But, I don't understand what "24.18 mm the hole size" means.  This is a circular cutout - what dimension does 24.18 specify?  For Revolve, we need an angle.
Jeff Strater
Message 5 of 16
jonhutty
Hi Jeff I mean has from when you start from 20.48mm then its 24.18mm in length the cut out. So from going in from the corners edge 20.48mm from that line measuring 24.18nm the dimension of the cut out and then from the top going down 11.00mm I hope that is more detailed which you wanted to know and thanks for all your help Jeff. I don't think I would be able to complete this without your help thankyou.
Message 6 of 16
jeff_strater
@jonhutty - I am still not sure I understand the second dimension (24.18)  what is that distance to be measured from?  I tried measuring that from the first line, but that extends beyond the edge of the body, so I don't think that is right.  I tried measuring from the same edge of the model, but that result is too small, I suspect.
Below is another method to try - sketching on the top face, and drawing some lines, and extruding downward by 11.
Jeff Strater
Message 7 of 16
jonhutty
Yes Jeff its suppose to go round the edge my friend to follow the face on so from the edge is 20.48mm then from that line its 24.18 which follows the face edge round the corner and 11.0mm down from the top edge which should leave a few mm to the bottom. I hope this is more helpful and you can understand why I have been stuck on this but thanks for your patience and added help. I will follow your video on how to do this on my file so thanks
Message 8 of 16
jonhutty
Hi Jeff i sorted that out my friend with the way you suggested and 2 line points where they needed to be the downward extruded worked perfectly. So thanks for all your help. I may need you for another task on this project I've created 13 smaller holes on the inside of a larger circle extrusion. But need one side of the 13 holes to be all joined together and all opened up halfway down the circle extrusion will run round a small revolve extrusion. I hope you can figure out what I'm trying to say ill send you a pic on what I'm trying to copy but thanks again for all your help this project is nearly finished just this last part to finish and hopefully once printed its perfect.
Message 9 of 16
jeff_strater
glad to hear it.  If you feel the issue is resolved, feel free to mark one or more responses as a solution ("Accept Solution").  This can help other users who may have similar questions find topics with answers.  Let us know how the rest of your project goes.
Jeff Strater
Message 10 of 16
jonhutty
There was 2 things i have left to do the above question and to be able to put a washer on the center circle extrusion half way up and about 3mm in depth. But that is one I have not done yet so if you could help me on that also that would be great thanks again for your assist.
Message 11 of 16
jonhutty
Will do Jeff just have 2 tasks left to do too finish this project and that the 2 above questions but ill post 2 pics of what I'm after doing ok jeff
Message 12 of 16
jonhutty
Here is 3 photos of what I'm trying to achieve i have the circled extrusion done with the holes. But to get the cut out where the holes are not joined fully anymore at one side thought of the revolve command too cut that section out. But maybe wrong and also how to create the center divide on the circular extrusion for the rubber washer to sit. I hope this tells you what I'm after and also the 3 pics let me know Jeff thanks.
Message 13 of 16
jonhutty
It is so the round magazine will rotate and has a stop that is why I have to do a part cutout on the circle extrusion. Hope this helps and you can put me in the right direction.
Message 14 of 16
jhackney1972
You need to attach your model, not just the screen captures.  We do not want to reinvent your work.
John Hackney, Retired
Message 15 of 16
davebYYPCU
Add dimensions to my sketches,
Step along the timeline to see it build.
Couldn't count the outline groves, so it's a guestimate
Message 16 of 16
jonhutty
Hi dave so the the mag is editable so I can add where to put the washer center ring and the dimensions if needed. I only properly started doing fusion everyday for the last few weeks. But starting to get there and thought I would try making my own magazine for my pcp. So thanks for the help buddy last night I drew 2 circles and used 2 lines to end the circumfrance where I wanted it. Then extruded and cut I don't know if its the best way to do it but it worked but doesn't look has tidy has yours. But im learning so thanks.
