Trying to create a sweep to cut head ache!
Message 1 of 8
Ok
It's fair to say that my use of fusion is more for the cam than anything else.
Its also true to say that my aspirations regarding my cad modeling are not normal. I'm more mesh orientated than cad block work.
So for a bit of fun I thought I would take a very quick break from my retopolgy studies and double funeral planning. To see if I could design a knife.
well I'm stuck! I can't create the triangle profile I want to sweep around the lower blade edge profile to create the bevel.
I had a look at the NYCCNC fusion Friday videos about making a sweep but I can't seem to get the required result.
Heres a link to video showing what I want to do.
https://www.youtube.com/watch?v=pUUAwnrUHHk&index=32&list=PL9tn9rGywKUUGyeBWX5Alt9yzBIp84sD8.
I have also attached the f360 file for you to see what want to do!
If you good folks can show me how to get what I want with this, I can move on! my head is fried now.
Thanks guys
Replies (7)
Message 2 of 8
TrippyLighting
The .f3d file is attached. I'll post the screencast when it's uploaded.
Message 3 of 8
Peter!
the fastest forum gun in the east coast!
Cheers mate. what was i doing wrong?
Message 4 of 8
TrippyLighting
While I delete some things in the screencast as there is an easier way to do it, there is nothing wrong in the design. It's just not complete.
Hopefully the screencast explains how I did it.
Message 5 of 8
Cheers Peter.
Out of interest how you would approach this from the start?
Message 6 of 8
TrippyLighting
I think I'd do it the same way. There is nothing wrong with your approach.
If the blade edge get's more complicated you can also try a loft as shown in this thread.
Message 7 of 8
i can see how a loft would work there.
i never though of looking at a loft! god to know if i ever do this again.
my original blade had loads more intersect points and different splines. but i thought redraw with less as less is more!
loft yeah i will try that in future.
Questions, can you turn the black info panel off on the screen cast? As it gets in the way of how you look at the tree on the left. Or is it a screen cast feature?
Message 8 of 8
PhilProcarioJr
@Anonymous
You should be practicing this in T-Splines! Smiley Wink Smiley Very Happy
Phil Procario Jr.
Owner, Laser & CNC Creations
