CUT feature in assemblies?
camstuff
camstuff
I work a lot with assemblies and would like to learn how to cut a feature without it cutting any other parts in the assembly.
I make sure the part I am working on (active) and do a CUT feature it cuts everything around or touching the part.
Thank you for any help or direction on what I am doing wrong.
TrippyLighting
If you can share your design that would certainly help.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @camstuff,
You can also turn off the visibility of the body/component that you do not want to be cut. As @TrippyLighting mentioned, I'll be able to give more explicit instructions or a video when I see the model.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
