Trying to create a Infill Bowl
bawd0043
bawd0043
I'm new to this fusion stuff, and I am trying to learn how to create a bowl that I can use infill changes to create contrast like this one- (https://makerworld.com/en/models/1545567-infill-dolphin-bowl#profileId-1622819)  to make my own mermaid design for my daughter.
I can make the inner bowl; however, I am having difficulty with the outer bowl lining up with the Mermaids of the inner bowl.causing overhangs when trying to print.
It was a complete accident that I even figured out how to get the outer bowl looking like it should.
Im sure there has to be an easier way that will make everything line up.
All suggestions are welcome I really would love to learn this technique.
TimelesslyTiredYouth
Can you provide the file that your working on so we can see what you've done till now.
My first thought after seeing the maker world to use the emboss tool on the ball, so you can wrap the design on the inside and outside, I will respond later with an example file unless someone else replies.
Kind regards
Ricky
P.S
I'd advice you to follow the Fusion's self-paced learning, integrated in the app, or watch "learn Fusion in 30 days" by product design online
Warmingup1953
I'm not sure what you mean by 'inner bowl' and 'outer bowl'...Isn't the dolphin bowl simply a bowl with dolphin shaped shaped holes (flush inside and outside with the bowl)  filled by a separate set of bodies that are dolphins?
laughingcreek
Is this a double post?  different user name, but the same odd terminology and file as this thread-
https://forums.autodesk.com/t5/fusion-design-validate-document/help-needed-fusion-360-design/td-p/13...
CGBenner
@bawd0043
Welcome to the forum.  For best results, I suggest sharing any file that you have started here in the forum, so the experts can take a look and offer their ideas.  Good luck!
Chris Benner
etfrench
There are two ways to do this.
1: Extrude the dolphin shape through the bowl. Split Body that using the inner and outer surfaces of the bowl. Combine/Cut the dolphin from the bowl using the Keep Tools option.  Circular Pattern that feature.
2. Create a bowl matching the inner face of the main bowl.  Create an Offset Face of the outside face of the inner bowl. Turn visibility of this off. Emboss the dolphin on the inner bowl using the thickness of the main bowl.  Split Body the dolphin from the inner bowl. Circular pattern it. Combine/Cut it from the outer bowl.
ETFrench
CGBenner
@bawd0043
Hello, do you still need help with this question?
Chris Benner
