Hi team,
I'm not sure if this is the place where an absolute beginner can get help but here's hoping.
I'm just getting started so thought I'd try something fairly easy - a storage tray. I've got the basic design by following lots of tutorials online. My tray is just 1mm thick and I thought that the lip might be a bit 'flexible' so I thought I'd strengthen it by adding a rim - maybe 2mm.
One way to do this (I thought) would be to create a 2mm diameter circle sketch on the XY axis at any point on the outer rim and then use the 'sweep' function. But I can't seem to get this to work.
What I'm doing is:
Construct > Midplane >between front and back vertical faces to give me somewhere to place the sketch
Create a sketch on this plane
Choose circle and then try to locate it on the outside edge.
This is where I get stuck. The circle doesn't constrain to the outside edge and remains 'floating' on the construction plane. Naturally - no constraint means I can't sweep it.
Dos this make sense to anyone?
