Help needed Fusion 360 Design
melcoe21
Message 1 of 12
melcoe21
I am a Fusion 360 newbie. I am trying to learn how to make a bowl that I have seen and printed on Makers World. I have attached the STL files and the 3mf.
I wanted to make a mermaid version for my daughter. I have managed to create the inner bowl fine. I got super stuck on the outer bowl, managing to make a version that looks like what I want, however does not line up with the inner bowl. This then causes overhangs in slicer.
There has to be a simpler way that will align everything than what I have tried to figure out.I have attached my fusion file so show what I have managed so far.
Replies (11)
Message 2 of 12
TimelesslyTiredYouth
Hi, nothing is attached, can you attach the model once more for us to view, and please don't double post.
Ricky
Message 3 of 12
Drewpan
If you have got the inner bowl working correctly then probably the easiest way to
get the outer bowl to "line up" is simply use the Thicken tool if you created it with
a Surface:
Or use the Press Pull tool if you have a Body as the inner bowl.
In terms of lining up your shape on the outside then simply use the
Extrude tool:
And set it to Join instead of Cut:
I would strongly recommend that you have a look at fusion RULE #0
that is pinned to the top of the forum. There are excellent learning
tutorials embedded within the Documentation and in the Self Paced
Learning.
Cheers
Andrew
Message 4 of 12
melcoe21
I thought they attached, sorry
Message 5 of 12
melcoe21
I tried everyone's suggestion, and thank you so much for the help. I think I stumbled on a workaround whilst trying all the suggestions. I'm still not sure it is the easiest way to achieve what I wanted. Doing a test print at the moment, so will see!
I have attached the file I used to print. Exported the parts I needed in STL and added them into the slicer as one part.
If anyone knows how to create this better would love to know.
Message 6 of 12
melcoe21
Thank you so much for taking the time to reply. All the help is appreciated. I did try the extrude tool as I thought it would be as simple as that; however, it would not let me select the bowl with cutouts on the base.
Using your theory, I then used the surface patch tool to create the mermaids. I thickened and moved them. I have attached the file below still hoping for a better or easier option being out there.
Message 7 of 12
Drewpan
This is a very complicated method to get the end result and I am not sure why you did
it this way. My first impression is that you could get rid of 90% of the timeline by simply
drawing this profile:
And then revolving it around the Z axis. The profile isn't quite the same as the finished
shape but with a little more care drawing it it could be. You could then either use Shell
to hollow it out or a surface and thicken it. Basically two steps. You have way too many
Planes that I can see very little use for.
I don't know why you have embossed the shape twice the way you have or why you have
cut the shape all of the way through. You could have embossed the shape on the inside
and then embossed the same shape on the outside. It would have lined up perfectly.
If the reason was to get a shadow effect that might be the reason but I am not certain
of this.
I am also quite confused as to why you have then split the bowl into two Components.
Are you planning on 3D printing this as two separate halves? You have two choices as
to how to print this, either as two components with no infill or as a single print with 100%
infill. Both would work but the no infill version would be quite weak mechanically.
I am currently having a go at this myself and will post my file when I am done.
Cheers
Andrew
Message 8 of 12
laughingcreek
I think you're working much to hard.  have a look at the attached.
Message 9 of 12
melcoe21
Hello thanks for reply. I did at first try the revolve method and had issues with the image pattern. I will be interested  very much in how you go about this with a lot more experience that I clearly have.
When I print I copied the setting from the original dolphin one
Inner bowl  no top or bottom shells or walls and 30% infill - I have tried it with one wall and think I like that better
The outside layer I do 100% infill and 2 walls
Message 10 of 12
melcoe21
OMG you made that look so easy!!! Your a ledgend.
Im going to print and see how we go and will post when printed.
It did come up non manifold edges but will give it a try anyway
Message 11 of 12
melcoe21
I am so impatient, I scaled down so I could see how it went. Could not be happier I'm thinking I need another image higher and in between so keen to try out doing it with your technique.
Message 12 of 12
TheCADWhisperer
@melcoe21
Once you get a version you are happy with - Attach it here to see how the process could be optimized.
