This is a very complicated method to get the end result and I am not sure why you did
it this way. My first impression is that you could get rid of 90% of the timeline by simply
drawing this profile:
And then revolving it around the Z axis. The profile isn't quite the same as the finished
shape but with a little more care drawing it it could be. You could then either use Shell
to hollow it out or a surface and thicken it. Basically two steps. You have way too many
Planes that I can see very little use for.
I don't know why you have embossed the shape twice the way you have or why you have
cut the shape all of the way through. You could have embossed the shape on the inside
and then embossed the same shape on the outside. It would have lined up perfectly.
If the reason was to get a shadow effect that might be the reason but I am not certain
of this.
I am also quite confused as to why you have then split the bowl into two Components.
Are you planning on 3D printing this as two separate halves? You have two choices as
to how to print this, either as two components with no infill or as a single print with 100%
infill. Both would work but the no infill version would be quite weak mechanically.
I am currently having a go at this myself and will post my file when I am done.
Cheers
Andrew
