07:38 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys
I have created two separate components, and am trying to use the align command to make them touch each other (face to face) so I can then combine them into a single component for 3D printing.
The problem is that when I use the align command, and select the two faces which I want to touch, then it shows as it it will move correctly, but once I press OK it moves back to where it was with a small gap between the two components.
How do I remove the gap so I can combine the components into a single component?
