Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Try to "extrude" a looping to make a cut in a design :s
8 REPLIES 8
Message 1 of 9
613 Views, 8 Replies
Hi!
I've a little problem and I don't know where I need to focus to solve it...
As you can see on the following pictures, I make a looping and another structure to fit in it. (it's the beggining of the Sonic looping design) But my problem is to cut this structure to have only it on the looping and not cover all and close the entrance...
I fist thinked about make an extrusion of the back of the looping to make a difference cut but extrusion didn't work on this kind of shape... I also try on surface but same result
I'm not an expert so I'm sure that I missed something but what?
Thanks for you help!
2020-09-01_09h12_31.jpg2020-09-01_09h12_44.jpg2020-09-01_09h13_11.jpg2020-09-01_09h13_18.jpg
What I want to do :
7a57fa859b56d7ed61ec8d5fd224c100
8 REPLIES 8
Message 2 of 9
chrisplyler
Export your file as an Archive (.f3d file), save it to your hard drive, and attach it to your next post.
Message 3 of 9
in reply to: chrisplyler
sorry i can't...
could you just explain me how to do please?
Message 4 of 9
TheCADWhisperer
Make up a dummy file that exhibits the same desired behavior and Attach here.
Message 5 of 9
in reply to: TheCADWhisperer
It's not possible to just have a process? Is it possible to extrude a looping to make a difference? Another solution?
Message 6 of 9
laughingcreek
always easier to explain after seeing a users model.  but take a look at the attached for 1 idea (there's probably dozens of ways to approach this)-
Message 7 of 9
in reply to: laughingcreek
Thanks a lot!
I have a question. In your example, you made carve the structure into the looping, but my looping is made with a profile like a U and I don't have any thickness under it. I know that I just can edit all profiles I use, but I want to know if it's possible to do it on another way (also to learn new techniques)
Message 8 of 9
chrisplyler
You could sketch a profile that you want to be cut along the loop, then sweep it using the loop as a guide, and set it to cut the structure.
Message 9 of 9
yes... I didn't think about this simple solution lol!
Thank you! ^^
