Troubles after restore system
Hi
After forced restore Windows 8.1 64 bit I have a great problem with start Autodesk Fusion 360. Attempt of the start is finished  with the message - see the picture trouble_1.jpg.
When I try to uninstall I can not do it - the process is finished unexpectedly without any message, On the list of programs, the icon for Autodesk Fusion 360 looks like on the picture trouble_2.jpg
 And when I try desperately install once again Autodesk Fusion 360 , I get the message like on the picture trouble_3.jpg - polish text is "can not find the file specified"
To my post  I enclose also file autodesk.webdeploy.streamer. I would not make the recovery of the system , because it is very personalized.
Thanks for support.
Ludwika
Here I enclose once again the pictures to my post, because the number of the attachments is close to 3.
svelez
It appears that there may be a mismatch between the installation record and the actual state of your system.
To reset it and start afresh, delete the folder C:\Users\krzysztof\AppData\Local\Autodesk\webdeploy completely, and re-install from the usual place.
Thanks , succeeded in.
Ludwika
