Trouble with long equation using IF parameter
01165479
Message 1 of 12
01165479
Hello, what I want to achieve, is simple "if there are x number of holes, perform this equation" via parameter.
I got "a" defined in mm and "hole" defined without unit.
I run into trouble when creating the unit less parameter for the required equation
"invalid string ";" in expression"
Here is my code
if((hole==2; (a / 2)); (hole==3; ((a * sqrt(3)) / 2)); ((hole==4; (a * sqrt(2)) / 2)); (hole==5; ((a * sqrt(50 + 10 * sqrt(5))) / 10)); (hole==6; a); (hole==7; (a / (2 * sin(PI / 7)))); (hole==8; (a * sqrt((2 + sqrt(2)) / 2))); 0)
Could anyone help me review this?
Replies (11)
Message 2 of 12
CGBenner
@01165479
Welcome to the forum.  I've moved your post here for better visibility.  Good luck!
Chris Benner
Message 3 of 12
g-andresen
Please share the file with the equation
File > export > save as f3d on local drive  > attach to post
günther
Message 4 of 12
g-andresen
have a look at Product Documentation
günther
Message 5 of 12
johnsonshiue
Hi! Either there is a bug in the Fusion equation parser or there is an inconsistent unit issue (not all terms have the same type of unit). Please share the f3d file here. The forum experts can help take a further look.
Many thanks!
Software Test Engineer
Message 6 of 12
etfrench
Impossible to tell without knowing how each parameter has been defined.
ETFrench
Message 7 of 12
g-andresen
1. each condition is introduced with an IF.
2. if you want a value without units, you must divide by mm at the end. (Reason: a has units)
3. the unit rad must be added for the sine, because otherwise Fusion assumes that PI is the number 3.14 and adds the unit deg.
@johnsonshiue  Is this intentional?
4. @johnsonshiue
the values PI ~ 180° and 2*PI ~ 360° are wrong for the sine.
(view in My Videos)
günther
Message 8 of 12
johnsonshiue
Hi Günther,
Many thanks for sharing the file and the comments! I do believe this is the intended behavior. Fusion equation is indeed unit sensitive. If you enter a value without a unit attached, the default unit for the particular function will be added. The default angular unit is degree, not rad. You may change it in the Preferences -> Default Units.
Thanks again!
Message 9 of 12
CGBenner
@01165479 Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 10 of 12
g-andresen
Many thanks for the feedback.
Is there an explanation for the sine 180deg & 360deg ?
günther
Message 11 of 12
johnsonshiue
Hi Günther,
Regarding the values returned from trigonometric functions, the minute numerical deviation is due to how these functions are being approximated numerically. Some programs limit the number of decimal places so that the noise is not shown. In Fusion, you may add a wrap around the functions by using "round()." With or without the wrap, the result should be the same.
Here is an explanation of why such deviation exists.
https://stackoverflow.com/questions/51820357/c-trigonometric-function-returns-unexpected-value
Many thanks!
Message 12 of 12
g-andresen
Many thanks for the info.
I came across this behavior by chance and don't currently have a design example where this could play a role.
günther
