Trouble with folding hinges and collison when folded
So, trying to make this folding table for gaming.  So designed the two halves of the table and then inserted two strap hinges from mcmaster-carr.  I believe I have set up the joints all properly and all, but when I go to move one half of the table, I can spin it right through the other half.
I've tried setting limits to the hinge rotation, but even though when pressing play it shows the desired limits, when I apply and then move the one half of the table again, it still moves past the desired limits I thought I had placed.  What am I doing wrong?
If there is a way to share what I have made, do let me know.  New to Fusion.
Thanks in advance.
I think this may be the way to share what I have done...
http://a360.co/2xYhK4U
Don't think that link worked, so will try this one:
http://a360.co/2vZcCjJ
TrippyLighting
You don't need two revolute joints to assemble each hinge.
Use a rigid joint to assemble the pin to one half, then use a revolute joint to join the other half to the pin .
In theory you would not even need the pin for the joint to work in Fusion 360 . You could create a revolute joint directly between the hinge halves.
Then, when you set the joint limit's it'll work.
The hinge model is what I got when I inserted, so assumed I would need the pin.  Will try making one of the hinge sides a rigid joint and then the other a rev joint and will get back to yous.
TrippyLighting
Well....of course a Mc Master Carr part would have a pin 😉
You would simply not need it ror a hinge to work in Fusion 360.
So, yeah, thank worked and it helped explain my error in making the two rev joints.  Thanks.
