02:37 PM
- Mute
- Permalink
- Report
The problem that I'm coming across happens when I try to project a sketch onto a complex surface. I'd like for the sketch to project evenly, then I'd like to extrude evenly across the surface, similar to the example attached.
I'm not able to get this to work correctly at all. The best I can do is extrude from the object, which doesn't produce the desired results. I've tried to project to a curved surface and split face but wasn't able to get either of these to work. Split face looks like it might work, but I'm not able to extrude cut certain parts of the sketch. I think that might leave angles in the extrusion even if it worked.
I'm using Fusion 360 for Mac.
