Trimming lines in sketch
12 REPLIES 12
Message 1 of 13
1519 Views, 12 Replies
I am having a major problem with trim in sketch.
In the last 20 minutes or so, Fusion360 has locked up 5 times so far while I was trying to create a profile in sketch.
Each time I have had to restart after an error report was generated, and each restart takes a couple of minutes.
I only have the last two error report numbers -
     CER_131646478
     CER_131646572.
Can anyone tell me what is going on?
Brett
12 REPLIES 12
Message 2 of 13
Ok, please tell me what is going on.
New error report number -
     CER_131647465
Brett
Message 3 of 13
HughesTooling
Are you having problems with all sketches of just a single sketch. If you are having problem in a single design\sketch can you export the f3d file and attach to this thread?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 13
in reply to: HughesTooling
Hello Mark,
Ok, exported file attached.
I have just checked and it is still doing the same thing.
I am trying to create another small rectangle on the right hand side of the sketch (see the left hand side).
I am aware that I could just mirror or copy the existing rectangle on the left across to the right, however, that does not solve the problem I am having with trim.
I have tried deleting and recreating the offset lines that I want to trim, the problem remains.
I don't think it is a problem with the lines, as the sequence in which I do the trimming affects which line segment fusion freezes on.
Brett
Message 5 of 13
Hi again,
In reply to your question as to whether only one sketch is affected.
Yes.
I have been working on another design for the last hour or so without any problems.
Brett
Message 6 of 13
HughesTooling
It all trimmed for me OK. Try reimporting the sketch attached to this thread and see if that's any different.
Mark
Mark Hughes
Message 7 of 13
Hi Mark,
Ok, thanks I will.
Brett
Message 8 of 13
Hi Mark,
Hmph, I tried uploading the file you tried and got exactly the same result. 2 or 3 trims into the sequence and fusion crashed.
I will try working around the problem, but that still means that a problem exists.
Brett
Message 9 of 13
HughesTooling
OK made it crash for me, if I trim the offset line on the left of the rectangle first then try trimming the others it crashes trimming from right to left seems to work!
Mark
Mark Hughes
Message 10 of 13
Ok, that's weird. It should not make a difference which way round the lines are trimmed.
Brett
Message 11 of 13
jiang_peng
Hi Brett,
I can not reproduce the crash with the attached file either. From the report, it appears related with the R-pattern. Do you still have the file which can reproduce the crash? Please send me the file if you still have it. My email address: jiang.peng@autodesk.com
Thanks for reporting the issue!
Message 12 of 13
HughesTooling
in reply to: jiang_peng
Trim the line with the offset constraint on it first, the vertical line on the left then try and trim one of the horizontal lines on the right.
Mark
Mark Hughes
Message 13 of 13
jiang_peng
Hi Brett,
I can reproduce the crash too with file. I've logged as FUS-25401.
