Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Trim tool wants to trim whole line
Jamieeade
Jamieeade
Community Visitor
Community Visitor
Hi, Im making a 2D guitar headstock design and trying to trim the curve in red but only where it extends into the circle. when I hover over the part it extends to the whole curve and doesnt register that the line is intersecting with the circle I made. the orginal design was from another headstock i made in fusion and imported as a DXF would that be the reason why it is doing that since i didnt make it from scratch?
kacper.suchomski
Hi
It's hard to judge this without the file, but in practice you don't need to trim it - Fusion will recognize closed areas for extrusion.
Kacper Suchomski
navya_gelli
Hi @Jamieeade ,
I wanted to check in and see if you saw @kacper.suchomski follow up questions and you still needed assistance, or if you found a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
All the best,
Navya | Community Manager
g-andresen
please share the file
File> export > save as f3d on local drive > attach to post
günther
