Tray Modelling help
Tray Modelling help
marks3U6W9
1,211 次查看
20 条回复
1 条消息(共 21 条)
Tray Modelling help
marks3U6W9
Hi. Would anyone know how to model up something like this? I can get close but am struggling to have the curve correctly follow the cut out top section. Many thanks
0 个赞
已接受的解答 (2)
1,212 次查看
20 条回复
回复 (20)
2 条消息(共 21 条)
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the post.
günther
0 个赞
3 条消息(共 21 条)
TrippyLighting
I personally would model this using T-Splines in less than 10-15 minutes.
I can do a screen recording in the evening (US-EST).
0 个赞
4 条消息(共 21 条)
marks3U6W9
That would be great thanks Peter
0 个赞
5 条消息(共 21 条)
marks3U6W9
Here's where I got to
0 个赞
6 条消息(共 21 条)
TrippyLighting
Again, screencast will come later:
7 条消息(共 21 条)
marks3U6W9
Thats very close thanks a lot Peter. If there's anyway to make the inside corner fillets any counter that would be great. Just looked at your Fusion file and don't seem to be able to figure out the workflow from the timeline so if you do have time to make a short video this evening that would be really kind. Thanks again.
0 个赞
8 条消息(共 21 条)
marks3U6W9
that should have read any rounder
0 个赞
9 条消息(共 21 条)
TrippyLighting
That's what I thought 😉
0 个赞
10 条消息(共 21 条)
marks3U6W9
Good morning Peter. Did you get a chance to do that screencast last night? Cheers
0 个赞
11 条消息(共 21 条)
TrippyLighting
已接受的解答
Nope, but I did now just now. It will take another  30 min or so for it to convert on YouTube.
0 个赞
12 条消息(共 21 条)
marks3U6W9
Peter that was bloody brilliant. Thanks very much indeed. I'm not familiar with the form workspace in Fusion at all so will spend some time going through your screencast in detail and try and replicate what you did. Always learning right? Am I right in thinking this would be a pretty tough thing to model in the regular solid workspace?
Thanks again. Really appreciate you taking the time.
13 条消息(共 21 条)
davebYYPCU
Depends on the level of detail you would be looking for, not tough or impossible, IMO forms do a better job.
Might help...
14 条消息(共 21 条)
marks3U6W9
Understood. I'll go with the way you did it then. Thanks again for the help Peter
0 个赞
15 条消息(共 21 条)
jhackney1972
已接受的解答
Here is my version of a tray using the solid modeling environment.  I hope it looks good to you.  Model is attached if it interest you.
John Hackney, Retired
0 个赞
16 条消息(共 21 条)
TheCADWhisperer
@marks3U6W9
The modeling technique I would use would largely be dependent on the actual manufacturing method that is intended.
Will you use standard tooling or do you have a 5-axis machine? Or are you simply going to 3D Print this?
0 个赞
17 条消息(共 21 条)
marks3U6W9
Thanks for the replies chaps. John appreciate you modelling it up. Will take a look when I next get to the desk.
cadwhisperer I don’t have a five access machine just a small three axis one. Would probably add the roundover on the underside at a router table.
0 个赞
18 条消息(共 21 条)
TheCADWhisperer
@marks3U6W9
Is the machine CNC controlled or manual control?
0 个赞
19 条消息(共 21 条)
marks3U6W9
Cnc controlled
0 个赞
20 条消息(共 21 条)
TrippyLighting
If it's a decent CNC machine, for example a Shapoko, you should have no problem creating this tray.
0 个赞
