how do i disassemble components?
rcbench_info
Observer Observer
rcbench_info
Observer
Observer
i have an imported component that has like 9000 bodies... fusion 360 says it has 9000+ bodies, and i would like to dissasemble it, or be able to modify the bodies individually....
from what i have read on forums i saw that i should upload the file (it is a non-functional replica firearm, just a warning if anyone doesnt want to see it)
attached are the files, so someone can inspect if there is something wrong or anything....
any help wouldbe appreciated, thanks in advance,
TheCADWhisperer
Can you get a STEP (*.stp) rather than IGES (*.igs) file?
I found multiple issues with the surface bodies.
If I had to convert the IGES - I would segregate the surface bodies into logical Components and the Stitch them into solids.  It would probably take about a week of effort.
rcbench_info
Observer
Observer
thank you, ill ask for the .stp file
